Pairing the inReach® Mini 2 for the inReach® Remote Widget
Some non-inReach® Garmin products have the ability to pair with the inReach® Mini 2 and use some of the inReach® communication features that it offers.
Even though both devices need to be in close proximity (10ft) to each other, it can be helpful to strap your inReach® device on your pack or person, and then use your smaller non-inReach® device for messaging, SOS, etc.
This article walks you through the process of getting these devices paired together.
Enabling the inReach® Remote Mode on the inReach® Mini 2
NOTE: These steps are not applicable when connecting to the Overlander® GPS navigator. If you intend to use your inReach® Mini 2 with the Overlander® GPS navigator, see - Pairing an inReach® to an Overlander® GPS navigator.
From the home page, press OK to open the main menu.
Select Settings.
Select inReach® Remote.
Select Status to toggle on inReach® Remote mode.
Enabling and Connecting the inReach® Remote Widget
Last, you need to pair your compatible non-inReach® device. Steps will vary by the type of device you are using.
Garmin Watches
TIP: If you have previously used another inReach® device with the watch and wish to remove it, this can be done by selecting it in the Sensors & Accessories menu of the watch. For detailed steps, see - Removing Sensors From Watches.
Access your Settings menu.
Watches with 5 buttons: Hold Up/MENU (middle left button) > Scroll to our select Settings.
Watches with 2 buttons: Press the top right button > Select Settings.
Select Sensors & Accessories or Connectivity > Sensors & Accessories.
Select Add New.
Select inReach®.
The watch will begin searching for and connecting to the inReach® device. This can take up to 60 seconds.
Select inReach® - (device number) once it appears on the watch.
Once connected, the inReach® Remote widget should be enabled automatically. If it is not, refer to "Customizing the Widget/Glance Loop" in your watch's owner's manual for instructions to add it. From the watch face, scroll to the inReach® Remote widget to see your messages. While viewing the inReach® Remote widget, select START/STOP to access the menu for SOS, Messages, or Tracking.
Edge® Cycling Computers
For steps to enable the inReach Remote widget on a compatible Edge computer, refer to your owner's manual and search for "Using the inReach Remote".
