Data Limitations of the Montana 600 Series
When sending or creating files for a Montana® 600 series outdoor handheld,1 keep in mind the following limitations:
  • 2,000 GPX files
  • 4,000 waypoints
  • 12,000 geocaches
  • 200 routes, 250 points per route; 50 points turn-by-turn routing
  • 200 saved tracks
  • 2,000 archive tracks2
  • 10,000 points per track
  • 500 custom map tiles
  • 250 BirdsEye Imagery files
  • Mapping segments3 vary by model:
    • Montana 600, 610, 650, 680: approximately 4,000
    • Montana 600t Camo, 610t, 650t, 680t: approximately 3,500 (due to internal mapping)
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 For Montana 700 series handheld limitations see User Data Limitations of the Montana 700 Series
2 Archive tracks do not count against GPX file limit; 1 archive track per gpx file.
3 See Related for more information on map segments.
Related
