Setting Up Incident Detection on a Garmin Device
CAUTION: Incident Detection is a supplemental feature that must be set up within the Garmin Connect™ app. It SHOULD NOT be relied on as a primary method to obtain emergency assistance. Neither your Garmin device nor the Garmin Connect app will make contact with emergency service on your behalf1.
NOTE: Forerunner® 945 LTE users, for specific details about safety feature on your watch see:  Forerunner 945 LTE: Safety Features
When a Garmin® device detects an incident occurrence, the Garmin Connect app on you phone can send your name and location (if available) to your Garmin Connect designated emergency contacts. Your location is determined using our LiveTrack location tracking feature. LiveTrack will create a real-time feed of your location during an activity. You must set up Incident Detection and emergency contacts in the Garmin Connect app.
What Are the Requirements to Use Incident Detection?
  • Incident Detection MUST be available and enabled for the activity profile being used. Information about which of your device's Activity Profiles support Incident Detection is available below
  • Incident Detection does not work with activity apps that are downloaded from the Connect IQ™ Store.
  • The Garmin device must have LTE service enabled (only available for certain products), or the Garmin device must be connected via Bluetooth® to the Garmin Connect app on a compatible smartphone. If using an iOS smartphone, the Garmin Connect app must be open in the background of the smartphone and cannot be closed.
  • For non-LTE Garmin devices, the connected smartphone must have a cellular signal with a subscribed data plan from a phone network provider.
  • The Garmin device must have a GPS signal when Incident Detection is triggered. For devices that require connected GPS, an active Bluetooth connection, which will maintain the GPS connection with the paired phone, is required for activation of Incident Detection.
  • Emergency contacts must be able to receive text and/or email messages.
  • For incident detection to function as intended with a Garmin watch, it must be worn on the wrist.
How Do I Set Up Incident Detection?
Emergency contacts must be added through the Garmin Connect app before Incident Detection can be used.
Setting Up Emergency Contacts
  1. Open the Garmin Connect app.
  2. Select More (lower right).
  3. Select Safety & Tracking.
  4. Select Safety Features.
  5. If prompted, Accept the requirements to use Incident Detection.
  6. Select My Information and input your information. When finished select the back or arrow option on the screen to return to the previous screen.
  7. Select Add Emergency Contact.
  8. Select from the list displayed. If your emergency contact is not listed select the three dots from the upper right corner then select Choose Phone Contacts or Create Contact.
  9. Check contact information for each contact added by selecting them from the list. Choose the three dots or Edit from the upper right corner to edit a contact.
  10. Select Send Request.
    • This will open your phone's messaging app. You will be able to send a message to your contact where they can opt in to receiving text messages from Garmin for the Incident Detection feature.
  11. Once finished use the back option to exit this menu option.
How Do I Turn On Incident Detection for an Activity?
Incident Detection will be enabled and ready to use with supported Activity Profiles once emergency contacts have been set up in the Garmin Connect app and those contacts get synced to the device.
Which Activity Profiles Support Incident Detection?
Activity profiles that support Incident Detection vary by device. Select your device below to view which activity profiles support Incident Detection.
Some Garmin products will display the message Incident Detection is not supported or Incident Detection Unsupported when using an activity profile that is not compatible with Incident Detection.
Edge® Cycling Computers
Select your Edge device below to reveal details.
Edge® 130 Plus
For this device, Incident Detection can only be enabled or disabled at the system level meaning turning off the feature will disable it for all the supported ride types below until you turn the feature back on. Incident Detection cannot be used with ride types marked as "Not Supported".
Ride Types:Support Type:
RoadSupported
GravelSupported
CommuteSupported
eBikeSupported
CyclocrossNot Supported
MountainNot Supported
eMountainNot Supported
IndoorNot Supported
Edge® 520 | Edge® 520 Plus | Edge® 820 | Edge® Explore 820
For these devices, Incident Detection is available for select activity profiles. The activity profiles that are turned on by default will be listed as "On". Incident Detection for the profiles marked "Off" must be enabled within the settings of the device.
Activity Profile:Default Setting:
TrainOn
RaceOn
IndoorOff
Edge® 530 | Edge® 830 | Edge® 1030 | Edge® 1030 Plus
For these devices, Incident Detection is available for the activity profiles listed below but is only turned on by default for the profiles marked as "On". Incident Detection for the profiles marked as "Off" must be enabled from within the settings of the device.
RoadOn
GravelOn
CommuteOn
TourOn
eBikeOn
CyclocrossOff
MountainOff
eMountainOff
IndoorOff
Edge® 540 | Edge® 540 Solar | Edge® 840 | Edge® 840 Solar | Edge® 1040 | Edge® 1040 Solar | Edge® 1050
RoadOn
GravelOn
CommuteOn
TourOn
eBikeOn
CyclocrossOn
MountainOn
eMountainOn
IndoorOff
Edge® Explore
The Edge Explore does not have individual activity profiles. Incident detections is active for any ride as long as you have it enabled.
Edge® Explore 2
RoadOn
Off RoadOn
IndoorOff
Garmin® Watches
Incident Detection will be available for the below activity profiles. Not all profiles will be supported by all watches. Refer to the activity profile choices on your watch to determine which ones are available.
Supported Profiles:
Run
Track Run
Trail Run
Ultra Run
Bike
eBike
Gravel Bike
Bike Commute
Bike Tour
Road Bike
Walk
Hike
Compatible Watches
  • Approach® S44
  • Approach® S50
  • Approach® S70 | Approach® S70 - TaylorMade® Edition
  • D2™ Air X10
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fenix® 5 Plus | fenix® 5S Plus | fenix® 5X Plus
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 245 | Forerunner® 245 Music
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • Instinct® E
  • Lily® 2 | Lily® 2 Classic
  • Lily® 2 Active
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu®
  • Venu® 2 | Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq 2 | Venu® Sq 2 - Music Edition
  • vívoactive® 3 Music | vívoactive® 3 Music (Verizon)
  • vívoactive® 4 | vívoactive® 4S
  • vívoactive® 5
  • vívoactive® 6
  • vívomove® 3 | vívomove® 3S
  • vívomove® Luxe
  • vívomove® Sport
  • vívomove® Style
  • vívomove® Trend
  • vívosmart® 5
Will Incident Detection Trigger if the Activity Is Paused?
Yes. The incident detection feature is active after you start the timer until you end and save or discard the activity recorded in a compatible profile.
Will My Activity be Saved When Incident Detection is Triggered?
Yes. When an incident occurrence is detected, the watch will automatically end and save your current activity. The watch will start an Incident Detection activity to track your current location until the Incident Detection is ended.
1 Watches that feature voice functionality can dial emergency services on your behalf if an incident is detected and you have set an emergency service number as your emergency calling number.
Related
