Setting up My Montana 700 Series to Track My Dogs
The following guide shows how to set up your Montana® 700 series outdoor handheld with a compatible dog tracking handheld so you can track your dogs on the larger Montana screen.
IMPORTANT: The Montana will not show the location of the dog tracking handheld, but will show the dog location.
 Setting Up the Montana 700 GPS Navigator and Dog Tracking Handheld
These steps work with the Alpha® 10, Alpha 100, Alpha 200, Alpha 200i, Alpha 200 Plus, Alpha 300, Alpha 300i, Astro® 320, Astro 430, Astro 900, and PRO 550 Plus dog tracking handhelds along with the Montana GPS navigator.
On the Montana 700 Series Handheld
  1. Touch Home to reach the main menu.
  2. Select Dog Track.
  3. Select Yes.
  4. Select Status.
  5. Select Search New.
  6. Select X once the device shows connection.
  7. Select DogTrack.
If your Montana is within range of your dog tracking handheld and there is a dog actively tracking on the handheld, you should now see that information in the DogTrack list, as well as on the Map screen.
Troubleshooting Your Systems
Enable Broadcast or Remote View on your Dog Tracking Handheld
NOTE: Ensure other broadcasting devices are powered off.
Alpha® 100
  1. Select Set Up.
  2. Select Dogs.
  3. Select Broadcast Dog Data.
  4. Select Enable.
Alpha® 10
  1. Select Set Up.
  2. Select Remote View.
  3. Select Status.
Alpha® 200, Alpha® 200 Plus, and Alpha® 300
  1. Select Set Up.
  2. Select System.
  3. Toggle on Broadcast Dog Data.
Astro®
  1. Select Set Up.
  2. Select Dogs.
  4. Select Enable.
Pro 550 Plus
The Pro 550 Plus uses ANT+ to share dog locations to your compatible outdoor watch and broadcast dog data by default. No other steps are required on the handheld. Ensure your handheld is up to date on the latest software.
