ecoRoute HD Cable not Pairing
There may be times when the ecoRoute HD cable will not pair with your device. Correcting this issue can be accomplished by following the steps below:
Update the device software
The software on your device can be updated using Garmin Express.
Enable the device's Bluetooth
The Bluetooth setting should be enabled by default on your device. Follow the steps below to ensure Bluetooth is enabled:
- Touch Settings
- Touch Bluetooth
- Touch Bluetooth to add a checkmark
Pair the ecoRoute HD accessory
For instructions pairing the ecoRoute HD accessory, go to Pairing an ecoRoute HD accessory cable to a Garmin device.
Reset the ecoRoute HD accessory and device
If the ecoRoute HD accessory and device still aren't pairing, reset both using the instructions below:
- How to use the ecoRoute HD accessory reset button
- Hold the power button on the automotive device for 8-10 seconds
