Transferring Inspection Files Using Web Services with the Garmin eLog App
An inspector may require the transfer of your record of duty status from the Garmin eLog™ Compliant ELD. These files will transfer in .csv format.  See the instructions below for steps to transfer the inspection files using the Web Services option.
Note: The Garmin eLog™ app must be actively connected to the internet and the Garmin eLog ELD adapter in order to send reports via Web Services.
Apple
1. Open the Garmin eLog app
2. Sign in to your driver profile
3. Touch Inspection
4. Touch Send Report
  • Review data for accuracy prior to sending the report.
5. Touch Yes
6. Enter an annotation if necessary
  • Any key phrase or code provided by the DOT officer during the inspection should be entered here.
    • Special characters and spaces are not permitted and there is a maximum of 60 characters.
7. Change the date range if necessary
8. Touch Web Services
9. Enter an email address and touch Send Report
  • The app will display "Enter your preferred email address to receive confirmation from the FMCSA and Garmin about your data submission"
eLog Send Report
 10. Touch OK
The email sent will have the RODS report attached.
Android
3. Touch Inspection
4. Touch the send reports icon
5. Touch Yes
eLog Android Web Services
10. Touch OK
dēzl™ 780 or dēzlCam™ 785 GPS Navigators
NOTE: An active Wi-Fi connection is required for this process.
3. Touch Inspection
5. Touch Yes
dezl 780 Web Services Send Report
10. Touch OK
dēzl™ OTR800, dēzl™ OTR810, dēzl™ OTR1000, or dēzl™ OTR1010 GPS Navigators
3. Touch Inspection
5. Touch Yes
 dezl OTR810 Web Services Send Report
10. Touch OK
Related
