(2020) Service Bulletin 2037 Rev A: GDL 69/69A SXM Software Version 5.51 for Non-GX000 Integrated Flight Deck Installations Only
PRODUCTS AFFECTED:
GDL 69 SXM and GDL 69A SXM units installed under Supplemental Type Certificate (STC) SA01487SE-D are affected.
NOTE
GDL 69 SXM and GDL 69A SXM units installed with a GX000 Integrated Flight Deck are not affected.
CERTIFICATION AUTHORIZATION:
STC SA01487SE-D
COMPLIANCE:
Optional: This Service Bulletin may be incorporated at the owner’s discretion and is not warranty reimbursable.
PURPOSE:
This STC Service Bulletin provides notification of STC SA01487SE-D Master Data List Revision Q update for the GDL 69/69A SXM Upgrade to Software Version 5.51.
GDL 69/69A SXM software version 5.51 contains the following changes:
- Improved TFR and METAR text
- Fixes bug where some displays would not receive weather products
- Adds support for HSDB2 products
- Added support for CONUS composite NEXRAD for all subscriptions
- Corrected a discrepancy which prevented the muting of audio
- Updated Combined NEXRAD coverage area to Caribbean
- Unsubscribed channels are now removed from the program and channel lists
- When equipped with a GMA, a new audio mode improves system wide audio experience
STC SA01487SE-D Master Data List Revision Q also adds the following products:
- GDL 69 SXM (011-03177-05)
GDL 69A SXM (011-03177-15)
