Deleted Data Reappearing on the Map After Syncing With Earthmate or inReach Sync
If you delete data from the Map page of the Garmin Explore™ website, and it eventually reappears, it is likely that same data is still on the device and being transferred back to the account through inReach® Sync or Earthmate® app. Data consists of waypoints, routes, and tracks.
To prevent this from happening, the data needs to be deleted from both the Map page and the associated inReach device. Steps for both are below.
IMPORTANT: Following these steps permanently deletes the data, and it will no longer be in the Garmin Explore account or the inReach device.
Deleting Data From the Garmin Explore Website and inReach Device
Once finished deleting the data on the website, you need to delete it from the inReach device.
Deleting Data From an inReach Explorer®, inReach SE®+, or inReach Explorer+
Deleting Waypoints
Select Waypoints.
Select the waypoint you wish to delete.
Press .
Select Delete.
Deleting Routes
Select Routes.
Select a route.
Press .
Select Delete.
Deleting Tracks
Select History.
Tracks are sorted by the date they were recorded, select one from the list.
Press .
Select Delete.
NOTE: This will also delete any messages and waypoints done that same day.
Deleting Data From an inReach Mini
Deleting Waypoints
From the home screen (page with status bar showing time/battery info), press OK.
Select Navigate.
Select Waypoints.
Select a waypoint.
Select Delete.
Deleting Routes
Select Navigate.
Select Routes.
Select a route.
Select Delete.
Deleting Tracks
From the home screen (page with status bar showing time/battery info), scroll down and select Tracking.
Press OK to see the current tracking intervals and start tracking.
Press OK again to reach the tracking menu.
Select Clear Log.
Select Yes.
Select Stop Tracking.
Once the above steps are completed, the data will no longer sync from the device back to the Map page of the Garmin Explore website.
To confirm that the data has been permanently deleted, sync the device with inReach Sync or Earthmate, and then check the Map page again. For steps, see Related.
