(2024) Service Advisory 23033 Rev C: ADS-B In Surface Targets
REVISION B:
Added GTS 825/855/8000 Resolution
PRODUCTS AFFECTED:
GTX 345/345R/345D/345DR/45R, GDL 88(H)/84(H), GNX 375, GTS 800/820/850, and GTS 825/855/8000 units (with software listed in Table 1) using ADS-B IN are affected.
Table 1 Product Affected:
UnitSoftware Versions
GTX 345/345R/345D/345DR/45RADS-B 2.00 through 3.31 (except 3.15) and 3.40
GDL 88(H)/84(H)v3.00 through v3.42
GNX 375Main v2.00 through v3.20
GTS 800/820/850v5.00 and v5.01
GTS 825/855/8000v4.00 through v4.04 (except v4.03.1)
ISSUE:
Slow-moving (less than 20 knots) 1090ES ADS-B and ADS-R surface targets may erroneously appear as directional. Figure 1 shows an example traffic display with both slow-moving directional and non-directional surface traffic. The selected surface target is erroneously shown with a directional symbol while the surface target near the top is correctly shown with a non-directional symbol (diamond).
NOTE
Airborne and UAT targets are not affected.
AV_KM1699039
PILOT ACTION:
Be aware that directionality of slow-moving (less than 20 knots) ADS-B In surface targets may be shown erroneously.
NOTE
The ADS-B SURF traffic display is to be used only to supplement what can be seen out the window (AC 90-114B section 2.4.3).
RESOLUTION:
Refer to Table 2.
Table 2 Resolution:
UnitCorrected Software Versions
GTX 345DRADS-B 3.32 (Garmin TSO Service Bulletin 23042)
GTX 345/345R/345D/345DR/45RADS-B 3.41 (Garmin TSO Service Bulletin 23031)
GTX 345/345R/345D/345DR/45RADS-B 3.15
GNX 375Main 3.21 (Garmin TSO Service Bulletin 23037)
GTS 825/855/80004.03.1
4.05 (Garmin TSO Service Bulletin 24010)
GTS 800/820/8505.02
GDL 84(H)/88(H)v3.43 (Garmin TSO Service Bulletin 23056)
Related
