Outdoor Handheld and Watch Compatibility With BlueChart G3 or LakeVu G3 Maps
LakeVü™ g3 and BlueChart® g3 maps bring more coverage detail for your use on the water. In order for the g3 maps to work as expected on an outdoor handheld or watch, a software update may be required.
You may still be able to use the chart if you already purchased it, however we cannot guarantee that appropriate features will work correctly unless the compatible software version has been loaded to the handheld or watch.
Example of Detail Level Between a Montana® 750i Outdoor Handheld and an ECHOMAP™ UHD 74sv Chartplotter
Montana 750i
Montana 750i Device LakeVu Map Example
ECHOMAP UHD 74sv
UHD74sv Device LakeVu Map Example
Outdoor Handheld and Watch G3 Compatibility
HomePort™ and BaseCamp™ software will not work with g3 charts. At this time, only the outdoor handhelds and watches listed below are compatible with BlueChart g3 and LakeVü g3 maps and some device will require a software update to ensure compatibility. To update the handheld or watch software, use the Garmin Express™ program.
Marine Chart Features on Outdoor Handhelds and Watches
NOTE: The Vision and Ultra versions of BlueChart g3 and LakeVü g3 mapping are not recommended and should not be purchased for an outdoor handheld or watch.
Handhelds and watches using g3 charts will provide basic chart detail. You will not have auto guidance, depth range shading, 1' foot contours, shallow water shading, relief shading, or raster charts. LakeVü g3 charts provide a lower detail for rivers as compared to lakes but will provide water depths and contours. Your handheld or watch must be at the software version listed or newer, as applicable, in order to be compatible with g3 charts.
Required Software Version for Handhelds and Watches
For downloadable charts, ensure you have adequate space available.
Required Software Versions
Model NameRequired Software Version
Alpha® 200 | Alpha® 200iAll software versions
D2™ Delta | D2™ Delta PX | D2™ Delta SAll software versions
Enduro™ 2All software versions
Enduro™ 3All software versions
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire EditionAll software versions
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire EditionAll software versions
eTrex® TouchAll software versions
fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus v7.10 or later
fēnix® 6 - Standard Edition watch and all other models in the fēnix 6 seriesAll software versions
fēnix® 7 - Standard Edition watch and all other models in the fēnix 7 series All software versions
fēnix® 7 Pro - Solar Edition watch and all other models in the fēnix 7 Pro series All software versions
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition All software versions
fēnix® 8 Pro - AMOLED Editions | fēnix® 8 Pro - MicroLED Edition All software versions
fēnix® E watch and all other models in the fēnix E series All software versions
GPSMAP® 62s | GPSMAP® 62st | GPSMAP® 62sc | GPSMAP® 62stcv7.10 or later
GPSMAP® 64 | GPSMAP® 64s | GPSMAP® 64stv5.40 or later
GPSMAP® 64scv3.20 or later
GPSMAP® 64x | GPSMAP® 64sx | GPSMAP® 64csxv2.10 or later
GPSMAP® 65 | GPSMAP® 65sv3.50 or later
GPSMAP® 66s | GPSMAP® 66stv3.00 or later
GPSMAP® 66sr | GPSMAP® 66iAll software versions
GPSMAP® 67 | GPSMAP® 67iAll software versions
GPSMAP® H1 | GPSMAP® H1i PlusAll software versions
GPSMAP® 78 | GPSMAP® 78s | GPSMAP® 78scv7.10 or later
GPSMAP® 79s | GPSMAP® 79scAll software versions
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sciAll software versions
GPSMAP® 276Cxv4.60 or later
MARQ® Collectionv3.00 or later
MARQ® Collection (Gen 2)All software versions
Montana® 700 | Montana® 700i | Montana® 750iAll software versions
Montana® 710 | Montana® 710i | Montana® 760iAll software versions
Oregon® 700 |  Oregon® 750 | Oregon® 750tv4.70 or later
Rino® 750 | Rino® 750t | Rino® 755tv4.00 or later
tactix® 7 - Standard Edition watch and all other models in the tactix 7 seriesAll software versions
tactix® 8 - AMOLED | tactix® 8 - Solar All software versions
tactix® Delta - Sapphire Edition watch and all other models in the tactix Delta series All software versions
For details on chartplotter and marine handheld compatibility with BlueChart g3 and LakeVü g3, see - Garmin Marine Chart Feature Compatibility.
Related
