inReach Mini Menu Options
The main pages of the inReach® Mini handheld contain all the information you need to operate your device. You can select the Up or Down buttons to scroll through the pages, and you can press OK while viewing one of these pages to access additional settings and options. The information below explains what settings and options are available for each of the main pages.
Home Page
Displays the date, time, and status icons (Status Icons). It also displays tracking and weather information when those features are in use. The Main Menu can be accessed from this page to adjust most settings on the inReach Mini.
Time, Date, and Battery Displayed on Home Page
Press OK to open the Main Menu. Select "Complete List of Main Menu Options" below to see all of the Main Menu options and their sub-menus. For more details on what each of these settings and options are used for, refer to your owner's manual.
inReach Mini Main Menu
Main MenuSub-Menu 1Sub-Menu 2
Send Preset →Preset Message 1 →Send
View Details
Preset Message 2 →Send
View Details
Preset Message 3 →Send
View Details
Start/Stop Tracking
New Message →Send
Select Contacts
Write Message
Pick Quick Text
Mark Waypoint
Navigate →Waypoints
Routes
TracBack
Utilities →Test Service
Contacts
Data Use →Presets Sent
Messages Sent
Tracking Points
Plan Details
Check for Updates (used to check for recent data plan changes made on explore.garmin.com)
Setup →Display →Brightness
Timeout
Tracking →Send Interval
Log Interval
Auto Track
Ext. Tracking
Bluetooth →Status
Forget Device (this option will not appear if it has never been paired)
Not Paired/Paired With (Phone Name)
Pair Device/Pair Again
ANT+ →Status
Verification
Device Number
Verified Devices
Messages →Ring Until Read
Sounds →Mute All
Volume
Message Rec.
Message Sent
Critical Alert
Power Off
Time →Time Format
Time Zone
Daylight Saving (this option will not appear if Time Zone is set to Automatic)
Units →Coordinates
Datum
Speed/Distance
Wind Speed
Temperature
Pressure
Bearing
External Power →Auto Off
Language →(select a language)
Owner Info →Enter Name
About This Device →Address
IMEI
Auth. Code
Hardware Ver.
Firmware Ver.
Regulatory
License
Recovery Options →Restore Defaults
Back to Top
Messages Page
Press OK to send text messages or view your message history.
inReach Mini Messages Page
Back to Top
Mail Check Page
Displays when the last mail check was done. The inReach Mini handheld will listen for new messages for 10 minutes after you send a message, and then again every hour. Press OK to force a check for messages.
inReach Mini Mail Check Page
Back to Top
Tracking Page
Press OK to start and stop tracking. While tracking, this page shows your distance traveled and average speed.
inReach Mini Tracking Page
Back to Top
Location Page
Displays your current GPS location and elevation.
inReach Mini Location Page
Press OK for the following options:
  • Share Location: Send your location details as text within a message
  • Mark Waypoint: Saves a waypoint at your current location
  • Enable/Disable Page Timeout: When enabled, the device will return to the Home Page after 5 minutes. If this option is not available, update your inReach Mini (see Updating the Firmware and Syncing Account Information to an inReach Mini).
  • Setup: Allows you to change the unit settings
Back to Top
Compass Page
Displays your heading and speed when you are moving.
inReach Mini Compass Page
Back to Top
Bluetooth Page
Displays the Bluetooth status.
inReach Mini Bluetooth Page
  • Status: Turns Bluetooth On or Off
  • Not Paired/Paired With (Phone Name): Displays whether or not the inReach Mini has been paired to a mobile device
  • Forget Device: Unpairs the inReach Mini handheld from the last mobile device it was paired to (this option will not appear if it has never been paired)
  • Pair Device/Pair Again: Select to pair the inReach Mini handheld with a compatible mobile device
Back to Top
Weather Page
Press OK to update the weather forecast or choose a different location for the weather forecast.
NOTE: Updating a forecast incurs data charges or additional usage charges.
inReach Mini Weather Page
Back to Top
