Fusion® MS-UD750 OEM Manual Software Update
Fusion® MS-UD750 OEM software version 2.00.331
as of November 1, 2016
Download (11.54 MB)
View installation instructions and system requirements
Notes:
  • USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
  • This firmware release also contains updates for DAB+ accessories and NRX remote controls.
  • Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the 'update' menu in the 'settings' menu to be compatible with your Fusion Entertainment System
Installation Instructions
  1. Insert a blank USB flash drive formatted in FAT32 with a capacity of at least 4gb and no larger than 32gb into the PC/laptop
  2. Download the FusionMS-UD750_12141 update file to the PC/laptop and open it
  3. Drag the Update folder onto the USB flash drive
    • The Update folder should now be the only folder on the USB flash drive
  4. Connect the USB flash drive to the USB Port of the stereo
  5. On the stereo, select Menu > Settings > Update > Update Software
  6. The DAB+ module and remotes can now be updated from the update menu if required
System requirements
  1. IBM-compatible PC running Windows 2000 or later operating system and an available USB port.
