Setting Up the Radio on a Rino 520/530
Select a channel and code to transmit on with your Rino® 520 or Rino® 530 outdoor radio. Channels 1-7 and 15-22 are GMRS*, channels 8-14 are for FRS. Be sure to tell the other members of your group what channel and code you are using so they can communicate with you.
To Select a Channel:
  1. Highlight the Channel field and press the Thumb Stick In.
  2. Select an available channel and press the Thumb Stick In to accept the selection.
To Select a Code:
  1. Select the Code field and press the Thumb Stick In.
  2. Select one of the thirty-eight (38) available codes. Press the Thumb Stick In to accept the selection.
NOTE: Using GMRS channels requires an FCC license. See the Owner’s Manual for details.
Rino 520 Channel Select
