Scorecard Showing as Not Ranked (NR) in Course Live Leaderboard
There are a few reasons a scorecard may show up in the course live leaderboard as NR or Not Ranked.
  • The scorecard settings were set to private.
    • View Privacy Options for scorecards in the Live Leaderboards to change.
  • The scorecard was uploaded from a device that does not have a handicap setting.
    • You can be added to the course rankings by manually adding a handicap.
Setting a Course Handicap
  1. Open the Garmin Golf™ app.
  2. Select Profile.
  3. Select Leaderboard.
  4. Select the course played.
  5. Select appropriate scorecard.
  6. Select Course Handicap.
  7. Insert appropriate handicap.
    NOTE: If handicap is unknown, it is recommended to insert 0.
  8. Select Save.
Inserting a handicap or removing the private setting from the scorecard should allow it to be viewed in the leaderboard. If the scorecard is not updated in the week it is active, you will not be able to change it.
