Automotive Device Not Detected by Garmin BaseCamp on a Mac Computer
USB communication issues can prevent your Garmin device from being detected by Garmin BaseCamp™.
Verify no Other Garmin Applications are Running on the Mac
When Connected to a Mac, These Devices Will Only be Recognized or Detected by one Application at a Time
For example, if the Garmin Express™ software is open and has detected the device, opening Garmin BaseCamp at the same time will result in BaseCamp being unable to find the device until both applications are completely closed and the desired application is re-opened.
NOTE: Devices with MTP Mode are prevented from appearing as a separate drive on a Mac computer.  For these devices, a Windows computer must be used.
To Force Quit Garmin Express or Garmin BaseCamp on Mac:
  1. Press Command + Option + Escape on the keyboard
  2. Select Garmin Express or Garmin BaseCamp from the list of applications
  3. Click Force Quit
NOTE: A second set of instructions may be required to force quit Garmin Express.
  1. Select the Triangle icon in the upper right corner and click Quit
  2. Click Quit again
The Garmin Express or Garmin BaseCamp program will now be closed.
To Keep Garmin Express From Opening when the Computer is Powered on or when a Garmin Device is Connected to the Computer:
  1. Click on Garmin Express by the Apple icon
  2. Click Preferences or Settings
  3. Remove the check mark from the following boxes:
    • "Always keep Garmin Express running in the background."
    • "Automatically launch Garmin Express when a Garmin device is connected."
NOTE: Removing the check marks will disable the ability for Garmin Express to automatically launch and perform syncs to a device using Garmin Connect.
Restart the computer after making these changes.
Verify your Device is Properly Connected
Most devices will display an icon on the screen indicating that the device is communicating with your computer.
No icon will be displayed on the following Garmin devices when connected to the computer:
    • Arctic Cat G8 Display
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • Garmin Catalyst™ Driving Performance Optimizer
    • dēzl™ 780LMT-S GPS navigator
    • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
    • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin fleet™ 770 management
    • Garmin fleet™ 780 GPS management
    • Garmin fleet™ 790 GPS management
    • Kawasaki RIDGE® 8" Tread® Display
    • Kawasaki Teryx® H2 10" Tread® Display
    • Overlander® GPS navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • Tread® - Overland Edition GPS navigator
    • Tread® - SxS Edition GPS navigator
    • Tread® XL - Baja Chase Edition GPS navigator
    • Tread® XL - Baja Race Edition GPS navigator
    • Tread® XL - Overland Edition GPS navigator
The Camper 795, RV 795, CamperCam 795, RVcam 795, dēzl™ LGV610, dēzl™ OTR610, dēzl™ LGV710, dēzl™ OTR710, dēzlCam™ LGV710, dēzlCam™ OTR710, Garmin Drive™ 53 GPS navigator and all Garmin Drive™  53 series, Garmin DriveCam™ 76, Garmin DriveSmart™ 66, Garmin DriveSmart™ 76, and Garmin DriveSmart™ 86 require additional steps to display the connections icon.
1. Select Tap to Connect to Computer
    • If you do not select Tap to Connect to Computer this choice will eventually go away, you will then need to select Settings first.
2. Select Tap to Connect to Computer again
3. Select Continue
You should now see the connection icon.
Connect the USB Cable Directly to Your Garmin Device and not the Mount (USB Ports on Mounts are for Charging Only)
USB Ports on the back of a Garmin Automotive GPS unit
NOTE: The device doesn't have enough power to communicate with the computer if the display is blank or only shows a battery icon when connected to the computer. Charge the device while driving using the vehicle power cable to ensure it has enough power.
Verify your Mac recognizes the Device
The System Information application on Mac can be used to verify the connection between a device and Mac. For more instructions, please refer to Verify the Physical Connection of a USB GPS Device to a Mac.
Device is not recognized by the Mac
Macs with only USB-C Ports:
Some newer Mac computers may only have USB-C or Thunderbolt ports. It is best to connect your device directly to the computer when possible. If your device has a USB-C port, you can use a USB Type C to Type C data transfer cable. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
Macs with M1 and Newer Chips and USB-C Ports:
Automotive devices with miniUSB or microUSB ports must use a USB-C to USB adapter along with the appropriate miniUSB to USB-A or microUSB to USB-A cable provided with the device.
Automotive devices listed below may need to use a USB 2.0 third-party hub in order for the Garmin device to properly detect the USB connection.
  • BMW Motorrad Navigator V and VI
  • Camper 760 caravan and motorhome sat nav
  • Camper 780 caravan and motorhome sat nav
  • Can-Am Spyder zūmo® 590LM
  • dēzl™ 560 GPS navigator
  • dēzl™ 760 GPS navigator
  • dēzl™ 770 GPS navigator
  • dēzl™ 780 GPS navigator
  • dēzl™ LGV500 | dēzl™ OTR500 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV700 | dēzl™ OTR700 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzlCam™ LMTHD GPS navigator with camera
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • Garmin Dash Cam™ 45
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 54
  • Garmin Dash Cam™ 55
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 65W
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
  • Garmin DriveLuxe™ 50 GPS navigator
  • Garmin DriveLuxe™ 51 GPS navigator
  • Garmin Fleet™ 600 series
  • Garmin Fleet™ 700 series
  • Garmin Speak™ with Amazon Alexa
  • Garmin Speak™ Plus with Amazon Alexa with Built-in Dash Cam
  • Harley Davidson Roadtech zūmo® 590LM
  • nūviCam™ LMTHD GPS navigator with camera
  • RV 760 RV navigator
  • RV 780 RV navigator
  • zūmo® 590 GPS navigator
  • zūmo® 595 GPS navigator
Macs with Other Types of USB Ports:
Connecting through a hub, USB extension cable, adapter, keyboard, or monitor is not recommended or supported.  Use the product compatible USB cable to connect directly to the computer.
Try a Different USB Cable
Mini USB Cable          Micro USB Cable             USB Cable Type A to Type C          USB Cable Type C to Type C
Ensure the USB Port is Working Properly
  • Try a different USB port on your computer and/or test the USB port with a different USB device.
  • On desktop computers, use the USB ports on the back of your computer.
  • Check for visible signs of damage to the USB port on the device such as a loose or sagging cable connection.
Laptop                         Desktop
Restart the Computer and Try Again.
  1. Select the Apple icon in the menu bar.
  2. Select Restart.
  3. Select Restart to confirm.
Device is Recognized by the Garmin Express™ Software but not Garmin BaseCamp
See Garmin BaseCamp Not Detecting Devices on Mac Catalina 10.15 or Big Sur 11.0 if you are on Mac Catalina or Big Sur.
Other programs may be actively communicating with your device while it is plugged into a computer. Try closing out other Garmin applications that may be reading your device.
  • Example: If Garmin BaseCamp is not seeing your device, but Garmin Express is, close Garmin Express.
  3. Click Force Quit
  2. Click Quit again
See below if other programs are not interfering:
Ensure BaseCamp is Up to Date
  1. Click BaseCamp in the menu bar
  2. Click Check for Updates
  3. Click Install Now and follow the prompts if an update available
Ensure the Garmin is Up to Date
  1. Open Garmin Express
  2. Add or Select your Garmin
  3. Click Install Now if any updates are available
  4. Follow the prompts in Garmin Express to complete the update
For More Help:
Visit the Garmin BaseCamp section of Support Center and you will find the available Product Support contact options in the Contact an Expert section.
