Things to Know About the JL Audio® MBT-RX and MBT-CRXv2 Bluetooth® Devices
Both the MBT-RX and MBT-CRXv2 are designed to deliver powerful (2 Volts), CD-like audio performance to your system without wires from your Bluetooth® v4.0 (A2DP) enabled devices from up to 35 feet (11 meters) away.
If your device uses the aptX® codec, you can take full advantage of this technology to stream the highest quality audio to either the MBT-RX or the MBT-CRXv2.
Connecting your device will take about 20 seconds; just select the device in your Bluetooth® settings screen.
Your iOS device should have the Bluetooth® function turned on before you power up the MBT-RX or MBT-CRXv2 in order for them to reconnect automatically, if not you may have to manually reconnect.
Your Android device should automatically reconnect regardless of when the MBT-RX or MBT-CRXv2 are powered up.
Both devices are designed with the marine and powersports customers in mind. The MBT-RX is IPX6 rated, which basically means you can spray it with a powerful water jet and not worry about it.
The MBT-CRXv2 adds control over your Bluetooth® device using AVRCP (audio / video remote control profile). This allows you to control track up & down, volume up & down, play / pause and power on / off right from the device itself, allowing you to tuck your device away in a dry location. Even with these controls, the MBT-CRXv2 is IP67 rated, which means it can be submerged in up to 1M of water for 30 minutes without any concerns.
Taking your favorite music with you has never been easier or sounded better!
