Will Rudder Feedback be Shared Across NMEA 2000 Network when Connected to a GHP 12 or GHP Reactor Mechanical Retrofit Solenoid Corepack?
The GHP 12 or GHP Reactor Mechanical Retrofit Solenoid Corepack requires that a rudder sensor be connected to the autopilot in order to properly steer the vessel. When a compatible rudder sensor is connected to a either autopilot, the rudder feedback data will be shared across the NMEA 2000 network.
