Automotive Device Deactivates Supplemental Map(s) When Restarted
Most Garmin automotive navigation devices come with a map preloaded to the device. It is also possible to add a supplemental map to the device via a download or a preloaded microSD/SD memory card. To see all of the maps which are currently used by your device, check the device's myMaps menu.
To Locate this Menu on your Device:
  1. Touch Settings
  2. Touch Map and Vehicle, Map, or Map Display
  3. Touch myMaps
    • Some models require you to touch the down arrow under Device Navigation Maps to view all maps
The map information should now be displayed. See the sample screenshot below:
In your device's myMaps menu, each currently loaded map can be selected or de-selected by touching the box to the left of a map name to add or remove a checkmark. Because a device can only display one map at a time, it is not advised to select a supplemental map like another country and the preloaded map at the same time.
If multiple maps are selected, the device will automatically deselect any supplemental maps once it is restarted, leaving only the preloaded map selected.
If you would like the device to use the supplemental map by default each time it is powered on, navigate to the myMaps menu, and ensure that only the desired supplemental map is selected. The device will not switch to the preloaded map upon restarting, as long as only one map is active.
