Transfer User Data To and From the Garmin Explore Website
With the Library, Collections, and Primary Collection features on the Garmin Explore™ Website, you can choose what data to transfer and receive from the compatible device.
Manually Syncing Garmin Explore Account Data on an Automotive Device
The compatible device, Garmin Explore™ app (Compatible with the Overlander® GPS navigator only), and your Garmin Explore™ website account all work in conjunction for you to access your user data while you are in the field. It is important to sync your device before going into the field because it requires an Internet connection. Always verify the data you want is in the compatible app and on your device before you set out on your adventure.
A data connection is required when syncing with compatible apps on your phone or device.
Refer to your owner's manual for instructions:
Arctic Cat G8 Display
Kawasaki RIDGE 8" Tread Display
Overlander® GPS Navigator
Tread® XL - Baja Chase and Tread® XL - Baja Race Edition GPS Navigators
Tread® and Tread® - Base Edition GPS Navigators
Tread® - Overland Edition and Tread® XL - Overland Edition GPS Navigators
Tread® - SXS Edition GPS Navigators
zūmo® XT GPS Navigator
zūmo® XT2 GPS Navigator
Understanding Library, Collections, and Primary Collection
Library
The Library is a list of all your user data on the Garmin Explore™ website. Any data created on the website or uploaded from a compatible Garmin product will be stored under Library.
NOTE: When using the zūmo XT2 and Tread devices, it is recommended to use the Tread® App for managing waypoints, routes, and tracks. The Garmin Explore website can be used to manage waypoints and tracks, but does not support route creation for the zūmo XT2 and Tread devices.
Collections
Collections are lists of data that can store selected user data from the Library, allowing for a less cluttered map, trip planning, or showing specific data in MapShare™ page. Collections also allow for syncing only some user data to compatible devices or even using Primary Collection to receive data in the desired collection.
Primary Collection
For new customers, the default setting will be to sync everything in your Library when you pair a new device. However, Primary Collections can be used to control where new data is transferred to in the Library's Collections from a compatible Garmin device when syncing from the Garmin Explore app or inReach® Sync. Data transferred to a Collection from a Primary Collection will still appear within the Library.
Selecting Items to Be Synced and Setting Primary Collection
Selecting your Collections to be synced will ensure that you are only transferring the data you want the next time you sync. You can set a Collection to be synced by selecting sync arrows on the map tab. Alternatively, you can easily select if you want your library to sync or what collections to be synced from the Plans & Devices tab. You may also want to set a Primary Collection. A Primary Collection will take data recorded from the device and will be automatically imported into a selected Collection next time you sync.
Selecting Collections to be Synced
  1. Log in at the Garmin Explore website
  2. Select the Plans & Devices tab
  3. Select Collections next to your device you wish to use
  4. Select Sync Selection
  5. Under Synced Collections, check the box for a collection
  6. Select Close
  5. Under Primary Collection, use the drop-down menu to select a Primary Collection for data to automatically sync to
  6. Select Close
Once you have set the items you wish to sync, follow the steps in the next section to sync your device before going out on your next adventure.
Related
