Reporting Map Errors for Overlander, Tread, and zūmo XT GPS Navigators
Garmin's map data is gathered through a number of different sources including local governments, principalities, etc. There may be an occasion where something is not reported correctly or wasn't able to be changed in time for the new version of mapping to be released.
We have provided an Error Report Form on our website that allows you to submit any findings regarding missing or incomplete locations or streets in the mapping. Be as descriptive as possible and attach any image files that shows the error.
Examples of Map Errors
  • Point of interest has moved or no longer exists.
  • Device routing inaccurately, giving wrong directions, or routing off of the road/trail (i.e. the path of road/trail is mapped incorrectly).
  • Map feature improperly named/numbered (roads/trails, water features, landscape features, etc.).
The coverage of roads and trails may vary between map products.
Reporting Errors for Maps Not Listed in the Error Report Form
When it comes to the following products, apps, and websites, the process used to report map errors is detailed below.
  • TopoActive maps
  • Garmin Explore™/MapShare webpages
  • Garmin Explore™/Earthmate apps
  • Mapping on the inReach® Explorer+
Reporting Map Errors for These Products, Apps, and Websites
  1. Go to the Error Report Form.
  2. Leave the Garmin Device field blank.
  3. Select Map Product, then scroll down and select Other Map - Not Listed at the end of the drop down list.
  4. Type the name of the map/website/app in the Other Map field.
  5. Add details in the Error Location Information section and complete all other required fields (marked with *).
Be as descriptive as possible and attach any image files that show the error.
Select Your Device Below for Instructions to Take a Screenshot on the Device:
Related
