Sending a Message with an inReach SE+ or inReach Explorer+
The inReach SE®+ and inReach Explorer®+ handhelds can send messages via satellite communication when used by itself, or while paired to an Android or iOS device through the Earthmate® app.
For instructions on how to pair the inReach® handheld and send a message through the Earthmate app, see Related.
For how to send a message from the device itself, refer to the steps below.
Sending a New Message
  1. Select Messages.
  2. Select New Message.
  3. Select a Contact or type a phone number, email or inReach address.
    • See Entering and Selecting Contacts below for detailed steps.
  4. Type a Custom Message or select a Quick Text.
    • See Custom Messages and Quick Texts below for detailed steps.
  5. Select Send Message.
Manually Entering Contact Information
  1. Select the To field.
    Type Recipients Field Highlighted in Green
  2. Type in the phone number, email, or inReach address.
    NOTE: Phone numbers needs to be in the following format (minus the brackets): +[Country Code][SMS number]. For more information on country codes, see - https://countrycode.org/
  3. Select Done.
    Done Option Highlighted in Green
  4. Repeat this process for each contact.
Using Saved Contacts
  1. Select the Contacts icon.
    Red Arrow Pointing to Contacts Icon
  2. Select any number of Contacts.
    Select Contacts Screen
    Contact names may be listed multiple times to allow the option to send the message to their email, phone, and/or inReach device. Different icons are used for the contact's email, phone, and inReach. An example of these icons is listed below:
      • White Letter Icon on Blue Background Email
      • White SMS Letters on Blue Background Phone
      • Two White Arrows Pointing Left and Right on Blue Background inReach
  3. Press X when done.
Creating a Custom Message
  1. Select the Message field.
    Type Text Field Highlighted in Green
  2. Enter a custom message.
    Keypad for Typing Out a Message
  3. Select Done.
  4. Select Send Message to send.
Using Shortcut Buttons While Entering a Custom Message
While entering a custom message, the arrow buttons and check button are used to select each letter and the other physical buttons are used as shortcuts to aide in message composition. As indicated at the top of the screen, the functions of these shortcuts are listed below:
  • Lightning Bolt Button Option - The lightning bolt button will allow you to choose a word from the list of suggested words.
  • Minus Button Option - The minus button will act as a backspace.
  • Plus Button Option - The plus button will insert a space into the message.
  • 3-Line Menu Button - The menu button will capitalize the next letter.
Using Quick Texts
  1. Select the Quick Text icon.
    Red Arrow Pointing to Quick Text Lightning Bolt Icon
  2. Select a message.
    Quick Text Message Selection List
  3. Select Send Message to send.
Related
