Forerunner 945 LTE Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only on the Forerunner® 945 LTE smartwatch.
The following usage assumptions were used to determine the battery life for the Forerunner 945 LTE. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
Forerunner 945 LTE Smartwatch Mode - Default Display Configuration
Notifications per Day90
Number of Interactions per Day160
Device-Generated Alerts per Day (Move or Goal Alerts)2
Hours per Day Outside of Bluetooth Range of Phone1
Display Brightness and TimeoutDefault Settings
Watch Face1Default
Number of Gestures per DayDisabled by Default
Average Number of Hours per Day Spent Outside5
Pulse Ox ModeDisabled by Default
Number of Minutes of Streaming Music0
Number of Timed Activities0
Number of LTE Minutes Used0
Battery LifeUp to 14 Days
Forerunner 945 LTE - Activity Mode
Number of Interactions per Hour10
Minutes of Interaction Post-Activity1
Number of Gestures per Hour8
Display Brightness & TimeoutDefault Settings
Assumed Temperature Range for Battery Life Specifications10C-40C
Battery Life - GPS ModeUp to 35 Hours
Battery Life - GPS Mode + MusicUp to 12 Hours
Battery Life - GPS Mode + LTE LiveTrack2Up to 10 Hours
Battery Life - GPS Mode + LTE LiveTrack2 + MusicUp to 7 Hours
1The Forerunner 945 LTE’s “default” watch face is the watch face present on the device when it is taken out of the box. The Forerunner 945 LTE is designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
2 The battery life of the device when using LTE will be impacted by location and network conditions. If the device is used in an area of poor LTE coverage or low signal strength, the battery life of the device will be negatively impacted.
Related
