Using Night Vision Mode on a Descent Mk3 Watch
The Descent™ Mk3 - 43 mm, Descent™ Mk3i - 43 mm, and Descent™ Mk3i - 51 mm watches have a unique Night Vision mode designed to be read while wearing night vision optics. With Night Vision enabled, the entire watch interface shifts to shades of green. Night Vision mode is designed so that the display will not flare out or create a blooming effect when using night vision optics, even when the backlight is activated.
NOTE: Night Vision will affect or disable other settings such as the Watch Face, Flashlight, Wrist Heart Rate, and Red Shift.
Night Vision Mode Watch Face
When Night Vision is enabled, the watch face will only show a simple display and watch face customization will be disabled. Symbols shown may include Eye with moon symbol Night Vision, Moon with Zz Sleep Mode, or Green circle with black rectangle inside Do Not Disturb, if they are enabled.
Green numbers and watch face symbols
For instructions on how to enable Night Vision, see your owner's manual.
Adjusting Night Vision Settings
Some Night Vision settings can be changed. Use the directions below to adjust settings for Night Vision.
  1. Hold MENU.
  2. Select System.
  3. Select Night Vision.
  4. Select an option:
    • Display: Allows you to set the Brightness level and the backlight Timeout interval.
    • Touch: Toggles the touchscreen on or off for while Night Vision mode is active.
By default, touch is disabled while Night Vision is active.
Related
