Searching Near a Different Location
Your device searches near your current location by default.  If your device cannot find the destination you have entered, it may be searching in the wrong area.
To Search Near a Different Location:
1. Touch Where To?
2. Touch Near Me or Near My Route at the top
3. Touch More to see all the available options
    • More will only be available if your are currently in an active route
3. Touch the preferred option in the list
Available Options:
Near Me Searches near your current location (this is the default setting)
Near a City Searches near a specific city you enter
Recent  Searches near a recently found location listed in the device's Recent menu
Saved Searches near a location from the device's Saved menu
Near My Route1 Searches along your currently active route
A Time Ahead1 Searches a specific time in 15 minute intervals along the currently active route
Near Destination1 Searches along the currently active route, but starts near the destination and works backward along the route
Select a Location Searches near your home address, a specific address entered, a recent address, a saved address, intersection, coordinate, or browse the map to select the location to search
To begin searching near your current location once again, return to the main menu to restore the default setting.
1These options are only available when you have entered a destination and your device is currently navigating an active route.
Try the Following Steps in Order if the Errors "No Matches Found" or "Cannot Find Search Results" Continue to Appear When Searching for a Destination:
