Updating Green Contours for Garmin Golf Products
With a Garmin Golf™ Membership Subscription, your compatible Garmin golf device can automatically update Green Contours by syncing with the Garmin Golf™ app. For more information on Green Contours, see Green Contour Data on our Garmin Technology page. Refer to your owner's manual for information on pairing to the Garmin Golf app. If your watch pairs to the Garmin Connect™ app, see Related below for information on how to connect it to the Garmin Golf app.
Green Contours can also be viewed in the Garmin Golf app on your phone.
NOTE: Not all courses support Green Contours. To see what courses support Green Contours, see Which Golf Courses Support Garmin Green Contours?
Downloading Green Contours
Updating Courses in the App
To manually update the Green Contour data on your phone follow the steps below:
Open the Garmin Golf™ app on your phone.
Select
Select Start a Round.
Search your desired course.
Select
next to the desired course. If Green Contours are available, they will download with the rest of the course.
Updating Green Contours on a Compatible Garmin Device
The five golf courses you use most frequently will be updated automatically when your device is paired and synced with the Garmin Golf app. For steps to manually update the Green Contours for your compatible device, use the steps below:
Start a golf activity on your compatible device.
NOTE: See Understanding Green Contours and Compatible Garmin Golf Products for list of compatible devices.
Select a course that has green contours available.
Follow the on-screen prompts to start the round.
When prompted, keep your phone nearby as the Green Contours download to the compatible device.
Once prompted with the completion of the download, press any button to finish the process.
After the download has finished, finish the on-screen prompts to proceed with your round. The Green Contour data will show when viewing the green display.
For more information on the Garmin Golf™ Membership Subscription, see Related below.
