Creating Waypoints and POIs in the Garmin Explore App
Waypoints or Points of Interest (POIs) can be created in the Garmin Explore™ app, then synced to the Garmin Explore™ website or a compatible Garmin device. You can find steps for this below.
Waypoints can also be created offline, while in the field, and synced to a compatible device. This allows for trip planning without an internet connection.
For steps on navigating waypoints or points of interset in the Garmin Explore app, see - Navigating to a Waypoint or POI in the Garmin Explore App.
Creating a Waypoint/POI at Your Current Location
Open the Garmin Explore app.
Select
Map.
Tap
Select Create Waypoint.
If needed, edit the details of the waypoint by selecting the name or a new icon, or select Details to edit the waypoint coordinates or add notes.
For more details on waypoint notes, see - Using Waypoint Notes in the Garmin Explore App.
Select Save.
Select
Add to Collection, if desired.
Creating a Waypoint/POI for a Different Location
- Open the Garmin Explore app.
- Select
Map.
- Touch on the map where you would like to place the waypoint.
- Select
Mark.
- Select Save.
- Select
