Specifications for Automotive Portable Friction Mounts
Garmin offers three different Portable Friction Mounts for our Automotive products.
Portable Friction Mount (bean bag base)
- Weighted bean bag base is roughly 8.125" x 7" (20.64 cm x 17.78 cm)
- Height of ball arm without base: 2.44 " (6.2 cm)
- Weight: 11.2 oz.
- Ball size: 0.67” (17 mm)
- PN: 010-10908-02
- Compatible with many devices with displays up to 7". Check the Compatible Devices in the above link.
- Flexible base is roughly 6.71" x 4.95" (17.05 cm x 12.57 cm)
- Height of ball arm without base: 2.7" (7 cm)
- Weight: 11.2 oz.
- PN: 010-11280-02
- Weighted bean bag base is roughly 8" x 8" (20.32 cm x 20.32 cm)
- Height with ball arm fully upright: 5.5" (14 cm). This may vary due to the adjustability.
- Height with ball arm collapsed: 2" (5.08 cm)
- Height of ball arm without base: 4" (10.16 cm)
- Weight: 2.33 lbs.
- Ball size: 0.87" (22mm)
- PN: 010-10908-03
- Compatible with many devices with 8" and 10" displays. Check the Compatible Devices in the above link.
