Trip Info Page of inReach Explorer+ or SE+ Not Updating
An inReach Explorer®+ or inReach SE®+ handheld only records and accrues trip statistics on the Trip Info page if Tracking for the unit is enabled. If the Trip Info of your inReach® device stays at zero or does not increase as you travel with your device you will need to use the instruction below to start tracking on the unit.
IMPORTANT: If your inReach device is active on a Safety Plan,1 Enabled plan, or Essential Plan, sending tracking points incurs an overage charge. If you do not want the device to send track points, set the Send Interval of your device to Off by selecting Settings > Tracking > Send Interval > Off. For more details, see Related.
Turn on the inReach handheld.
Select Tracking.
Select Start.
If you would like to compose a message with your MapShare™ link2 to friends or family member select Share, otherwise select Not Now.
NOTE: This screen will not appear if it was disabled in Settings > Tracking > Prompt for MapShare.
Return to the Trip Info page of the device and confirm that data is being recorded.
Tracking and Logging will begin on the device. Points will be sent from the device to the online account using the Send Interval and the inReach will record points to display in the unit using the Log Interval.
When an inReach handheld is fully powered off the tracking on the device is turned off as well. The next time the inReach handheld is powered on the tracking will not be active until it is started again. All other inReach devices with a display screen can be set up to automatically enable tracking when the inReach device is powered on. Refer to your owner's manual to find how to access the Auto Track setting of your inReach device.
1 The Safety subscription plan is no longer available for purchase. The Safety plan has been replaced by the Essential plan.
2 If LiveTrack™ location sharing has been enabled on your account, a link to your LiveTrack profile will be included in the message. For more details on LiveTrack, see - LiveTrack for inReach.
