"There is a problem with the Microsoft .NET installation" Error in BaseCamp
A corrupt user configuration file can cause Garmin BaseCamp™ software to fail to launch and display the error. There is a problem with the Microsoft .NET installation. Please uninstall and reinstall all versions of the Microsoft .NET Framework.
Delete the Contents of the GARMIN_Corp User Configuration Folder:
Windows Vista and Newer:
- Hold the Windows Key (
) and press R
- Enter %userprofile% in the Open field and click Ok
- In the folder that opens up, AppData is a hidden folder. If you don't see the AppData folder, click View at the top, then click the box next to Hidden Items to put a check in it.
- Open the AppData folder
- Open the Local folder
- Open the GARMIN_Corp folder
- Delete all files in the GARMIN_Corp folder
Windows XP:
) and press R
- Open the Local Settings folder
- Open the Application Data folder
Once this folder is emptied, Garmin BaseCamp software should launch normally. If the issue persists, see Related Content.
NOTE: Deleting this file will reset Garmin BaseCamp software's preferences to default. All other user data (waypoints, tracks, routes, maps, etc.) will be preserved.
