1. Select the desired video to view in the Garmin Drive app
Delete a video by touching and holding the video and then touching the
Trash icon.
2. Trim the video as desired by touching and dragging the arrows on either side of the timeline.
3. Touch Export to send the video to your phone's photos:
- Export can take several minutes, depending on the length of the clip.
- When finished, the app will show Export Complete 100%
- Exported video will be accessible in your phone's photos.
- Trimmed videos will be accessible in your phone's photos while the original untrimmed video will remain in its original location, Saved or Temporary, in the Gallery.
- The exported video will be saved in the Garmin Vault for compatible dash cams:
- Compatible Vault devices: The Garmin Dash Cam™ X110,, Garmin Dash Cam™ X210, Garmin Dash Cam™ X310, Garmin Dash Cam™ 47, Garmin Dash Cam™ 57, Garmin Dash Cam™ 67W, Garmin Dash Cam™ Mini 2, Garmin Dash Cam™ Mini 3, Garmin Dash Cam™ Live, Garmin DriveCam™ 76, and CamperCam, and RVcam 795.
- The Vault will upload the video when connected to an active Wi-Fi connection or via your smartphone's cellular connection when this feature is enabled.
- Uploading takes some time and is not immediate.
4. To share video do one of the following:
- Go to your Photos on your phone, select the desired video, select your phone's share icon, and select the desired sharing option from those your phone displays.
- Go to the Garmin Vault for compatible Vault devices, select Secure Share, and follow the prompts. See Using the Vault Storage with a Garmin Dash Cam Device for more information
