Navigating with a Rino 520HCx and 530 HCx
Using a Rino® 520HCx or Rino® 530HCx outdoor handheld you can navigate to a waypoint, city, exit, or a contact’s location. Using optional detailed maps, you can also navigate to points of interest, addresses, and intersections.
To Begin Navigation Using Find
- Press and hold Enter to display the Shortcuts Menu.
- Highlight Find and press Enter.
- Highlight Waypoints and press Enter to display the list of nearest waypoints.
- Highlight the desired waypoint and press Enter.
- With the Waypoint Page displayed, highlight the Go To button at the bottom of the page and press Enter to begin navigation.
- The Map Page automatically opens to guide you to your destination.
Compass Page
The two main components of the Compass Page are the compass ring and the pointer. As you move, the compass ring rotates showing your current heading at the top of the display. The pointer points toward your destination. When the pointer is aligned with the vertical line at the top of the compass ring, you are on a direct course toward your destination. The Rino 520HCx has to be moving to navigate. If you are standing still or moving very slowly, the navigation data may not be accurate. When you are stationary, an electronic compass (Rino 530HCx only) becomes functional to maintain directional orientation. Follow instructions in the Owner’s Manual for calibrating the electronic compass the first time you use it.
