Garmin GPSMAP and FLIR Camera Compatibility
Several GPSMAP® chartplotters became compatible with FLIR cameras after receiving the 10.00 software update. See Garmin Marine Device Software Updates for steps to install a software update.
NOTE: Chartplotters offer basic controls for the camera like image mode (IR, visible, etc.) and color mode. However, Garmin has no control over alarm creation or setting specific temperature monitoring locations on the image.  This is done via FLIR programming; consult with FLIR for guidance on how to do this.
Older discontinued FLIR Fixed Mount Marine cameras with Pan/Tilt/Zoom (PTZ)
NOTES:
• These cameras have one or more analog CVBS outputs for the video and are controlled via ethernet (Garmin Marine Network or Garmin BlueNet™ network).
• Installations must have at least one CVBS input on one of the networked MFD's or use an Axis Video Encoder to bring in the video.
• If a camera is not listed, there is either no support for that camera or the camera has not yet been tested for compatibility.
FLIR Models:
  • M324CS
  • M324XP
  • M324L
  • M324S
  • M612L
  • M617CS
  • M618CS
  • M625CS
  • M625L
  • M625S
  • M625XP
  • MD324
  • MD625
  • M132
  • M232
  • M300C
  • M332
  • M364C
  • M364C LR
  • M400
  • M400XR
  • M500 series
Compatible Chartplotters:
  • GPSMAP® 7x2 chartplotters | GPSMAP® 9x2 chartplotters
  • GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters
  • GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters
  • GPSMAP® 12x3 chartplotters | GPSMAP® 16x3 chartplotters
  • GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
  • GPSMAP® 80xx chartplotters | GPSMAP® 82xx chartplotters
  • GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters
  • GPSMAP® 8700 chartplotters
  • GPSMAP® 90xx chartplotters | GPSMAP® 92xx chartplotters
Non PTZ FLIR Fixed Mount Marine Cameras
NOTES:
FLIR Models:
  • MD324
  • MD625
Related
