Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Installing the Latest Software to Your Approach CT10
Approach® CT10 sensors will receive a software update through the Garmin® golf watch that it is paired with, such as an Approach S20 or S60. The paired Garmin golf watch receives available updates for your Approach CT10 from two sources:
  • Garmin Connect™ App - If your Garmin device is paired to Garmin Connect App, it will download software updates automatically behind the scenes while your device is connected to your mobile phone. There are no steps required for you to take to obtain the latest software. Generally, any released updates will take up to a week to download before automatically or prompting to install on your device. Download Garmin Connect App for your phone
  • Garmin Express™ program - The Garmin Express program provides the ability to check and offer software updates automatically each time you connect your device to the computer. Download Garmin Express for your computer
Updating an Approach CT10
The steps below must be completed outside of a round of golf, and with the CT10 sensor in proximity of the device it is being used with. The steps will need to be performed to update each of your Approach CT10 sensors.
  • Navigate to Club Sensors > Software Update. The watch will display all sensors that have an update pending.
    • This option will only appear if there is an available update. If no updates are available, this option will not appear under Club Sensors.
    • Detailed steps to navigate to Software Update can be found below.
  • Select a club to update. The watch will then display a message depending on if the club is connected or not, alongside the abbreviated club name.
    • Selected club is connected: Installing Update.
    • Selected club is not connected: Get out your [club name].
  • When the update completes, the watch will display "Update Complete".
    • After 5 seconds, the watch will return to club selection if there are pending update or will show Club Sensors if all updates are complete.
Navigating to Software Update
Select your watch to view steps.
Approach Series
Approach S12 and G12
  1. Press Ok.
  2. Select Golf Settings.
  3. Select Club Sensors.
  4. Select Software Update.
Approach S20
  1. Press Ok.
  2. Select Settings.
  3. Select Club Tracking.
  4. Select Club Sensors.
  5. Select Software Update.
Approach S40 and S42
  1. Press and hold the button.
Approach S44 and S50
  1. Press and hold the Top button.
  2. Select Settings.
  3. Select Golf Settings.
  4. Select Club Tracking or Club Sensors.
Approach S60 and S62
  1. Press Menu.
  2. Tap Settings.
  3. Tap Sensors & Accessories.
  4. Tap Club Sensors.
  5. Tap Software Update.
D2™ Mach 1 Series
  1. Press and hold Up/Menu.
  2. Select Sensors & Accessories.
Descent™ Series
Descent G1 Series
Descent G2 Series
Descent Mk1
Descent Mk2 Series
Descent Mk3 Series
Enduro™ Series
Epix™ Gen 2 Series
fenix® Series
fenix 5 Series
  2. Select Settings.
  3. Select Sensors & Accessories.
fenix 5 Plus Series
  2. Select Settings.
fenix 6 Series
fenix 7 Series
fenix 8 Series
  2. Select Watch Settings.
  3. Select Connectivity.
  4. Select Sensors & Accessories.
  5. Select Club Sensors.
  6. Select Software Update
Forerunner® Series
Forerunner 935 Series
  2. Select Settings.
Forerunner 945 | 945 LTE | 955 | 965 Series
Forerunner 970 Series
  6. Select Software Update.
MARQ® Collection Series
Instinct® Series
Instinct 2 Series
Instinct 3 Series
tactix® Series
tactix 7 Series
tactix 8 Series
tactix Delta Series
Venu® Series
  1. Select START.
  2. Select Settings.
What Do I Do If the Update Fails?
If the update fails, the progress bar will fill up and turn red. The update can fail up to 3 times and will display: Update failed. Reconnect sensor to try again. After 10 seconds, the watch will return to Installing Update from Step 2 if the club is connected. If the club is not connected or you have reached maximum amount of attempts the watch will display: Update Failed. This will show for 5 seconds.
