Use TPMS and Bluetooth at the Same Time
The Tire Pressure Monitor Sensor (TPMS) uses ANT technology to connect with a compatible zumo device. When connected to a phone and/or headset via Bluetooth, a zumo 390, 395, 590, or 595 can still connect to TPMS without issue.
It is possible that the zumo will momentarily display a messaging stating "Sensor is disconnected" while attempting to connect. This is more likely to occur if Bluetooth is used simultaneously. Despite the message, the zumo should still pair to all TPMS products in use, even if the zumo's Bluetooth is not disabled.
