(2022) Service Bulletin 22050 Rev A: GTX™ 35R/GTX 45R/GTX 3X5 Series Main Software Version 2.70 and ADS-B Software Version 3.40
PRODUCTS AFFECTED:
The following GTX 35R/GTX 45R/GTX 3X5 series units are affected:
ModelAppliance P/N
ModelAppliance P/N
 GTX 325011-02974-00
 GTX 345011-03302-0( )
 GTX 335011-03300-0( )
 GTX 345 GPS011-03302-4( )
 GTX 335 NV011-03300-2( )
 GTX 345R011-03303-0( )
 GTX 335 GPS011-03300-4( )
 GTX 345R GPS011-03303-4( )
 GTX 335R011-03301-0( )
 GTX 345 NV011-03302-2( )
 GTX 335R GPS011-03301-4( )
 GTX 345 NV, GPS011-03302-6( )
 GTX 335D011-04331-00
 GTX 345D011-04333-00
 GTX 335DR011-04332-00
 GTX 345DR011-04334-00
 GTX 35R011-04286-0( )
 GTX 45R011-04287-0()
CERTIFICATION AUTHORIZATION:
TSO Authorization
TSO Authorization does not provide installation airworthiness approval. Separate installation airworthiness approval is required for type-certified aircraft. Notification of revision to any Garmin STC(s) will be provided under a separate service bulletin.
COMPLIANCE:
Optional: TSO Service Bulletin 22050 may be incorporated at the owner’s discretion.
PURPOSE:
GTX 35R/GTX 45R/GTX 3X5 Series Main Software Version 2.70 contains the following changes:
  • The Transponder Control Format 1 ARINC 429 input format has been expanded to process altitude data provided by a Mode S control panel (MSCP) using labels 203 and 204
  • A new configuration item, Mode S Control Panel Altitude Source, has been added to allow configuration of the resolution of pressure altitude data received from a MSCP
  • Unit configuration has been expanded to support selective processing of Traffic Information Systems Broadcast (TIS-B) targets on GTX 345(D)(R) and GTX 45R units, when installed with TAS/TCAS
  • A new configuration item, ADS-B Pass-Through Mode, has been added to enable/disable output of ADS-B In data to an ethernet port
  • Air/ground determination logic has been improved to prioritize applicable sensor inputs (ground speed, air speed, radio altitude) which indicate airborne conditions over an on-ground remote air state, resulting in an airborne determination
  • Added support for AHRS bench calibration using the GTX Install Tool
  • Expanded the equipage data provided with ARINC or RS-232 to Garmin GTX 820, 825, 850, or 855 to include the state of the transponder
GTX 35R/GTX 45R/GTX 3X5 Series ADS-B Software Version 3.40 contains the following changes:
  • Added support for ADS-B pass-through mode for flight data logging to be available with ethernet
  • Updated AHRS algorithms to improve performance of internal AHRS
  • Added support to disable processing of airborne TIS-B targets when TIS-B processing is configured for “Enabled for ground traffic only.” This is supported when the GTX is installed with a TAS/TCAS.
  • Fixed an issue where Bluetooth disconnected when multiple devices were present
  • Miscellaneous improvements to traffic correlation
