Accessing the Connect IQ Store
Below are steps to access the Connect IQ™ store from either your smartphone or a personal computer.
Access the Connect IQ Store From a Smartphone
For most devices, you can use the Connect IQ Store app to access the Connect IQ Store. Otherwise, you can follow these steps in the Garmin Connect™ app:
Open the Garmin Connect app.
Select More (bottom right).
Select Connect IQ Store.
Sign into your Garmin Connect account if prompted.
Select the device you want to shop the Connect IQ Store from My Device if you have more than one Garmin device paired to Garmin Connect app.
Search and select the app, widget, or watch face that you want to install to your device.
Access the Connect IQ Store From Garmin Connect Web on a Personal Computer
- From a web browser, sign into your Garmin Connect account.
Select
(upper-right corner).
Select Connect IQ Store under the device you wish to add Connect IQ apps, widgets, or watch faces to.
Anything that you have selected to install will do so after the next successful device sync.
