Updating the GHC™ 50
The GHC™ 50 marine autopilot instrument can be updated through either the Marine Network, BlueNet Network (software version 33.10 or after) or from the ActiveCaptain® mobile app.
Note: The GHC™ 50 marine autopilot instrument will not update through NMEA 2000. The GHC 50 can not be updated through a Legacy Software update over the Marine Network
Updating the GHC™ 50 marine autopilot instrument through ActiveCaptain® mobile app:
The GHC™ 50 marine autopilot instrument has the ActiveCaptain® app functionality with no microSD / SD card required. Updating the GHC 50 through ActiveCaptain® mobile app will update the instrument and all other connected Garmin devices on the NMEA 2000 system.
Power the GHC™ 50 instrument on
select ...
select Global Settings
select Garmin ActiveCaptain®
This option is only available if the GHC™ 50 instrument is not connected through the Marine Network or BlueNet Network to a chartplotter
select Wi-Fi Network
select the Wi-Fi OFF option to change the status to Wi-Fi ON
select Okay to configure the Wi-Fi connection
create the network name and select Done
The name of the Wi-Fi Network should be unique and not the same as any local Wi-Fi for ease of pairing a smart device.
create the network password and select Done
connect to the Wi-Fi network through the smart device's Wi-Fi settings
open the ActiveCaptain® mobile app on the smart device and allow the application to search and connect to GHC ™ 50 instrument's Wi-Fi Network
select My Marine Devices in the ActiveCaptain® mobile app on the smart device
under Software Updates Available select Download
Downloading the Software Update From a Full Wi-Fi Source
disconnect from the GHC™ 50 instrument's Wi-Fi and connect to a true Wi-Fi source to easily download the update, such as home Wi-Fi
Enabling Software Updates Over Mobile Data
select Settings > Data Usage > and under Software Update select Wi-Fi or Cellular
this allows the smart device to be connected to the GHC™ 50 instrument while downloading the software update through mobile data, as long as there is a strong enough mobile data connection
if the software download has completed over wi-fi and not using mobile data while connected to the GHC™ 50 instrument
"Software Updates Ready to Transfer" will appear once the download has completed
connect back to the GHC™ 50 instrument Wi-Fi
the software updates automatically start transferring to the GHC™ 50 instrument
follow the prompts on the GHC™ 50 instrument to install the software updates
This will update the GHC™ 50 instrument and all connected NMEA 2000 devices
restart the GHC™ 50 instrument when the GHC™ 50 instrument prompts
the system will power cycle and return to Heading Hold screen and function will be restored to normal with updated software
Updating the GHC™ 50 marine autopilot instrument through the BlueNet Network:
The GHC™ 50 marine autopilot instrument can be updated through the BlueNet Network if the GHC 50 is running on software 33.10 or greater and connected through the BlueNet Network port to a BlueNet Network compatible chartplotter.
If used in a hybrid network utilizing a Garmin BlueNet 30 Gateway the software update must be initiated from the BlueNet Network compatible chartplotter.
See, Garmin Marine Device Software Updates, for updating software through the chartplotter.
If the GHC™ 50 marine autopilot instrument is prior to software version 33.10 then the GHC™ 50 instrument must be updated through either the ActiveCaptain® app or from a connection to a chartplotter through the marine network.
Updating the GHC™ 50 marine autopilot instrument through the Marine Network:
The GHC™ 50 instrument software can be updated if connected through the Marine Network to a chartplotter
The software update will be ran from the chartplotter when utilizing the Marine Network connection
