Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Marking and Deleting Waypoints on a GPSMAP Handheld
There are a couple of different ways you can both mark and delete waypoints on a GPSMAP® 62, 64, 65, 66, or 67 series outdoor handheld. Steps for all of these can be found below.
Marking a Waypoint Using the Mark Button
  1. Press MARK from any page.
  2. Coordinates and information for the current location will display.
    • From this page, the following fields can be edited: Symbol, Name, Note, Location, Elevation, Depth.
      • Use the directional pad to highlight a field to edit, then press ENTER to select it.
      • After editing a field, select Done within the on-screen keyboard to save changes to the field.
      • For detailed instructions on editing location coordinates, see - Manually Entering Coordinates on a GPSMAP Handheld.
  3. Select Done or Save at the bottom to save the waypoint.
You can find the saved waypoint in the Waypoint Manager.
Marking a Waypoint Using the Map
  1. Press PAGE until the Map page is displayed.
  2. Use the directional pad to move the cursor to a location on the map.
  3. Press ENTER.
    • More than one option may display. Select an option from the list.
  4. Press MENU.
  5. Select Save as Waypoint.
  6. A confirmation will display that the waypoint was successfully saved. Select OK.
Deleting an Individual Waypoint
NOTE: When waypoints are deleted from the GPSMAP 64, 65, 66, or 67 series, they will also be deleted from the library in the Garmin Explore™ app the next time you sync.
  1. Press MENU twice to reach the main menu.
  2. Select Waypoint Manager.
  3. Select a waypoint.
    • Use the directional pad to move the cursor and press ENTER to select it.
  4. Press MENU.
  5. Select Delete.
  6. Select Yes or Delete to confirm.
The selected waypoint should now be removed from the Waypoint Manager.
Deleting All Waypoints
NOTE: When waypoints are deleted from the GPSMAP 64, 65, 66, or 67 series , they will also be deleted from the library in the Garmin Explore app the next time you sync.
  3. Press MENU.
  4. Select Delete All.
  5. Select Yes or Delete to confirm.
All of the waypoints should now be removed from the Waypoint Manager, indicated by "No Results Found" being displayed on the screen.
