Replacing an Approach S10 Watch Band
If the band for your Approach S10 is starting to look worn, has broken, or you just got a new watchband, this article will help you replace the old band and purchase a new band.
Tools Needed to Replace the Band
  • A clean workspace
  • The Approach S10
  • Replacement band
  • A T5 Torx driver  (provided when purchasing a replacement band from Garmin.com)
Replacing the Band
Replacing the band on your Approach S10 takes just a few steps. Before getting started, watch this video to see the process in action:
Removing the Band
  1. Locate the screws on the inside of the band by the watch housing.
  2. Use the Torx screwdriver to remove the screws.
  3. Pull the watchband away from the housing.
The band can now be replaced.
Installing the Band
  1. Push the replacement band into place until it clicks.
  2. Use the Torx screwdriver to screw the screws back into place.
You have now successfully replaced your band.
Purchasing a Replacement Band
If the band on your Approach S10 needs to be replaced because it has broken, torn or otherwise become unusable, replaceable bands can be purchased on our website at Approach S10 Replacement Watch Bands.
