inReach Mini Series Battery and Charging Specifications
The inReach® Mini and Mini 2 handhelds do not require much voltage for power and charging them can be done using any commercially available adapter that charges USB devices.
A typical wall adapter with a USB Type A interface will have a 1-3 amp output.
Both the inReach Mini and Mini 2 handhelds will charge at their limit of less than 1 amp, regardless of the adapter. The charging adapter will supply whatever voltage is requested of it from the device.
NOTE: inReach device batteries are not removable or replaceable.
Battery Specifications: 1 battery, 1 cell, 1250 mAh at 3.6V
