Using Different Map Datum to Search for Coordinates on Automotive Devices
Your device allows you to search for coordinates using different map datum.
Note: The datum cannot be adjusted for all coordinate formats on some devices.
To Change the Map Datum Format:
  1. Touch Where To? or Search
  2. Touch Coordinates
  3. Touch the wrench icon
  4. Touch Datum
  5. Select the desired map datum from the list
  6. Select Save
Your device will now allow you to search in the datum of your choice. Repeat the above steps if and when a different map datum is required.
