My Approach G30 is in the Wrong Language
If your Approach® G30 golf handheld is set to the wrong language and you need to change it, the instructions below will guide you through selecting the correct language. If the language is incorrect on your first usage of the device, follow the steps for a factory reset.
Changing the Language
- Power on the Approach G30 handheld.
- Touch
- Touch
once.
- Touch the second to last option.
- Select desired language.
You have now changed the language on your Approach G30 handheld.
Performing a Factory Reset to Change the Language
If you were unable to change the language on your device using the steps above, a factory reset can be performed to get the device back to the initial setup to choose a language.
- Power on device.
- Wait until text appears at the bottom of the screen.
- Press and hold on the upper left corner of display.
- Release display when it says "Do you really want to erase all user data?"
- Touch Yes.
The reset on the Approach handheld is successful if the device power-cycles and comes up with the language selection screen.
NOTE: Any scorecards saved to the device will remain after a factory reset.
null
