Garmin Panoptix Transducer not Recognized by Connected Chartplotter
If a Panoptix™ transducer is not being recognized by the chartplotter, use the following troubleshooting steps:
  • Check that the transducer is wired to power correctly. Try a standalone 12-volt battery if using a fuse block/bus bar. Check the fuse to see if it is blown
  • Check that the transducer's Ethernet plug is plugged into one of the marine network ports on the chartplotter, try a different network port on the chartplotter (if available
  • Check that the software is up to date on the chartplotter. Marine device software updates can be accessed here
  • Check that the chartplotter is compatible with the Panoptix. For a list of compatible chartplotters, see below:
Panoptix™ PS21-TM/TR transducer
  • echoMAP™ Chirp 7x chartplotters | echoMAP™ Chirp 9x chartplotters
  • ECHOMAP™ Plus 7x chartplotters | ECHOMAP™ Plus 9x chartplotters
  • ECHOMAP™ UHD 7x chartplotters | ECHOMAP™ UHD 9x chartplotters
  • GPSMAP® 7x1 chartplotters
  • GPSMAP® 7x2 chartplotters | GPSMAP® 9x2 chartplotters
  • GPSMAP® 7x3 chartplotters | GPSMAP® 9x3chartplotters
  • GPSMAP® 8x0 chartplotters | GPSMAP® 10x0 chartplotters
  • GPSMAP® 10x2 | GPSMAP® 12x2 chartplotters | GPSMAP® 12x3 chartplotters
  • GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
  • GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters | GPSMAP® 87xx chartplotters
Panoptix™ PS22-TR transducer
  • ECHOMAP™ UHD 7x chartplotters |ECHOMAP™ UHD 9x chartplotters
  • ECHOMAP™ Ultra chartplotters
  • GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters
  • GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 Touch, Plus chartplotters
  • GPSMAP® 12x3 chartplotters
Panoptix™ PS30 transducer
  • ECHOMAP™ Plus 7x chartplotters | echoMAP™ Plus 9x chartplotters
  • ECHOMAP™ UHD 7x chartplotters | echoMAP™ UHD 9x chartplotters
Panoptix™ PS31 transducer
  • GPSMAP® 10x2 chartplotters |GPSMAP® 12x2 Touch, Plus chartplotters
Panoptix™ PS51 transducer
  • GPSMAP® 8x0 chartplotters |GPSMAP® 10x0 chartplotters
  • GPSMAP® 10x2 chartplotters | GPSMAP® 12x2, Touch, Plus chartplotters
  • GPSMAP® 74xx chartplotters | GPSMAP® 76xx Schartplotters
  • GPSMAP® 84xx chartplotters | GPSMAP® 85xx chartplotters | GPSMAP® 86xx chartplotters | GPSMAP® 87xx Series chartplotters
Panoptix™ PS60 transducer
Panoptix™ LVS12 transducer
LiveScope™ LVS32 transducer
If the chartplotter still does not recognize the Panoptix transducer, then the transducer would need to be replaced. Contact Product Support to replace the transducer.
