Map Missing or SD Card Not Read on a Honda Gold Wing
See the troubleshooting below if your Honda Gold Wing (2006-2008) appears to be missing the map or the device is not reading the map SD card:
- Check the map information to see if the map card is being read
- Remove and reinsert the SD/CF Card
Ensure you are using the correct map region SD card
- North American Honda Gold Wing model years 2006-2008 will update using a preloaded CompactFlash (CF) memory card
- The update will include two CF cards; one containing the mapping of the Lower 49 States and the other containing the mapping of Canada, Alaska, and Border States
- Ensure you are using the card for the appropriate region
- You cannot use a United States map update card in a bike purchased in another market and vice versa
- Perform a hard reset on the Gold Wing box
- See Honda Gold Wing Navi Map Update not Installing Correctly for instructions
- Visit a Honda Gold Wing dealer
