Accessing the Keel Offset, Temperature Offset, and Calibrate Boat Speed settings on a GNX™ series marine instrument
On a GNX™ series marine instrument, the Keel Offset, Temperature Offset, and Calibrate Boat Speed settings are located under the Depth parent menu. The Depth menu will only be present if a steady (non-flashing) depth metric is available to the display.
To access these settings:
- Press the Menu button
- Select Setup
- Select Data Sources
- Select Depth
- Select the number listed here (this number will be different for each transducer as it is a unique internal identification number)
