What is the SonarChart Live Mapping Feature?
SonarChart™ Live allows you to create a high-definition bathymetry map that displays on your device in real-time while navigating. The new chart appears as an additional layer over either Nautical Chart or SonarChart using your . SonarChart Live is an excellent way to monitor the improvements your survey will bring to SonarChart because contours are instantly seen while you are collecting sonar logs.
