Correcting Low Volume on the Tread SXS and Tread Overland Edition Devices
If you are having trouble hearing the sound coming from your device, ensure that the volume is set to an audible level. Overall volume can be adjusted by using the volume buttons on the back of the unit.
Additional volume controls can be found in the device's settings.
To Check the Volume Level:
- Open the
Settings menu
- In the Device section, touch Sound & notification
- Confirm the desired volume for any that apply:
- Navigation
- Radio Fist Mic Speaker
- NOTE: The Radio Fist Mic is not available for the Arctic Cat G8 Display and Kawasaki RIDGE 8" Tread Display
- Media
- Call
- Alarm
- Notification
The volume should now be set to the desired level.
