Venu Sq 2 Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only on the Venu® Sq 2 and Venu® Sq 2 Music smartwatches.
The following usage assumptions were used to determine the estimated battery life for the Venu Sq 2. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
Notifications per Day | 50 |
Number of Interactions per Day | 160 |
Device-Generated Alerts per Day (Move or Goal Alerts) | 10 |
Hours per Day Outside of Bluetooth Range of Phone | 1 |
Display Brightness and Timeout | Medium and Short |
Watch Face2 | Default |
Number of Gestures per Day | 750 |
Average Number of Hours per Day Spend Outside | 5 |
Pulse Ox Mode | Disabled by Default |
Number of Timed Activities | 0 |
Battery Life | Up to 11 Days |
Average Number of Hours per Day Spent Outside2 | 5 |
Average Number of Hours per Day Sleep3 | 8 |
Display Timeout | Always on |
Battery Life | Up to 3 Days |
Number of Interactions per Hour | 10 |
Minutes of Interaction Post-Activity | 1 |
Number of Gestures per Hour | 25 |
Display Brightness & Timeout | Medium and Short |
Assumed Temperature Range for Battery Life Specifications | 10C - 40C |
"GPS-Only" Mode Battery Life | Up to 26 Hours |
"All Systems" GPS Mode Battery Life | Up to 20 Hours |
"GPS-Only" Mode with Music Battery Life | Up to 7 Hours |
Average Number of Hours per Day Spent Outside1 | 5 |
Watch Face | Default |
Display Brightness | Medium |
Display Timeout | Short |
Pulse Ox Mode | Disabled |
Auto Activity Start | Disabled |
Battery Life | Up to 12 days |
1 The Venu Sq 2 utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
2 The “default” watch face for the Venu Sq 2 is the watch face present on the device when it is taken out of the box. The Venu Sq 2 is designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
3 The average number of hours per day of sleep is determined by the user-configured bed and wake times (a "sleep period"), not the number of hours the user actually sleeps. During this sleep period, the device's display is turned off. As a result, setting a shorter sleep period may decrease the battery life experienced in display always on mode.
