1. Touch Apps
2. Touch Trip Planner. Touch the down arrow to scroll.
3. Touch New Trip
4. Touch Select Start Location
- NOTE: The Start Location is the first stop on the route. You can use your current location as the starting location, but it isn't necessary. The device will skip your current location if that is where you are when it begins to navigate.
5. Locate the starting point using the search options
6. Touch Select
7. Touch Add Location to add a second point
8. Follow steps 5 through 7 to locate and add up to 30 total points. Touch a point to show additional options.
9. Touch Select Destination and follow steps 5 and 6 to select a final destination
10. Touch Next. The route will now calculate
11. Touch Save
12. Type the desired name for the route and touch Done
