Using the Custom Map Sets Feature on the Montana 700 Series
The Montana® 700 series outdoor handhelds with the release of software version 8.20 have a feature called Custom Map Sets. To update your software see - Installing Software Updates and Managing Maps with the Montana 700 Series.
This feature allows you to create groups of maps that can be easily toggled on or off when using the device for different activities. This can be especially helpful if you are using other Garmin maps, such as TOPO 24K or HuntView Plus, in addition to the preloaded mapping in the Montana handheld.
NOTE: This feature is designed to be used as an alternative method for configuring maps on the device. We recommend disabling Automatic Maps when using Custom Map Sets. For more details on the Automatic Maps feature and how to disable it see - Viewing Topo Maps When Multiple Maps are Loaded to a Montana 700i/750i.
IMPORTANT
  • Worldwide DEM Basemap should always be enabled when creating a Custom Map Set.
  • BirdsEye Satellite Imagery and custom maps cannot be included in Custom Map Sets. These maps will need to be enabled/disabled manually.
  • When multiple detailed maps are loaded to a handheld, they fall in to a specific hierarchy. City Navigator® maps at the top, and Topo maps below. This causes Topo maps to not be visible unless City Navigator is disabled.
Creating Custom Map Sets
  1. Touch Image of House Icon to reach the Main Menu.
  2. Select Setup.
  3. Select Map.
  4. Select Configure Maps.
  5. Select Map Sets.
  6. Select +Create Map Set.
  7. Enter the name for the new map set, then select Image of Check Mark.
  8. Select maps to add to them to the new map set, then select Image of Check Mark.
Deleting Custom Map Sets
  2. Select Setup.
  3. Select Map.
  5. Select Map Sets.
  6. Select the name for the new map set.
  7. Select Delete
Enabling or Disabling Custom Map Sets
NOTE: This feature is designed to be used as an alternative method for configuring maps on the device. If Custom Map Sets are not enabling/disabling as expected, manually disable all maps on the device through the Setup menu before attempting to enable/disable through the Custom Map Sets feature again.
From the Setup Menu
  2. Select Setup.
  3. Select Map.
  5. Select Map Sets.
  6. Select the toggle to the right of a Map Set to enable/disable it (toggle down and gray = off).
From the Map Screen
  1. Select Image of Map Layers Icon.
  2. Select the Custom Map Set you wish to disable.
  3. Select the Custom Map Set you wish to enable.
    Example
    "Hiking" is currently enabled under Custom Map Sets, which was set up to include the TopoActive and Public Land maps. Select Hiking to disable it before selecting Driving, which was set up to include the City Navigator map.
    Image of Changing Custom Map Sets
